G3 numatics solenoid bank fault reset
jreyesm1988
Apr 2016
Miami
19
Hello there, i have a g3 series solenoid bank whit a fault code that says "valve power off", i went online with the g3 using the web browser but i can't find a way to reset this fault, i can't recycle power because i can't stop production, if someone knows a way to do it please help me out, thanks
Those modules have 2 power wires. One for continuous power to feed your inputs, and comms. Another that should be run through your safety circuitry. When you block a light curtain, or hit Estop, that alarm comes up.
I just checked out the G3 numatics line and they seem pretty awesome. Does anyone know if there is a classified version for use in hazardous locations and if the solenoids are usable with CNG vs air?
Hi all. Please can anyone assist me with a Devicenet EDS File or link for a Numatics G2-2 solenoid valve bank. Need to do configuration on a...
732
Hello, I've dealt with Communication faults on these ethernet nodes a few times but I never feel like I have the right solution. i usually replace...
682
Anyone got a manual for one of these? I cant find anything online.
1,304
Does anyone have any alternatives to the Numatics 502 manifolds that have Ethernet/IP adapter functionality alongside the valves? If they have m12...
3,465
Good morning, I have a dispenser that spits out ring gears for a robot to grab. This process has been running as expected for years. Currently...
2,109
