OB81 Programming
finskhan
Oct 2006
Multan
87
hello guys
Im newly born baby in the world of PLC.I was studying the OB81 which is programmed for the battery indication.When i study the sample programme in the siemens manual i found two different variables one is OB81_FLT_ID and the other is OB81_EV_CLASS.I was really confused with two variables used at the same time.When OB81_FLT_ID can set the variable so why we use the OB81_EV_CLASS.So we can use only one varible OB81_FLT_ID to programme the OB81 or it is requrired the OB81_EV_CLASS.Plz if u have some idea plz share it with me.
Regard
Finskhan
OB81_EV_CLASS allows you to differentiate between "coming" and "going" faults.
OB81_FLT_ID tells you what the fault is.
Highlight OB81 in Simatic Manager and then press F1 to call up the Help file. There you'll find everything explained in the detail you need.
hello guys Im newly born baby in the world of PLC.I was studying the OB81 which is programmed for the battery indication.When i study the sample...
1,866
Hi Every one, I am working on S7-300 PLC and CPU is 315 2 DP 315-2af03-0ab0/ v1.2. Total number of racks 3 (1 CPU with IM360 and others are...
2,386
When performing a download on this PLC I get a message that OB81, OB84, OB101 and OB102 cannot be downloaded and do I wish to proceed? Any ides...
1,469
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
212
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
134
