Oh no another motor question
Dave Steer
Nov 2002
Devon
27
Hi all
Sorry to keep posting these non PLC questions. Does anyone know of a site that has a circuit diagram of a star/delta (Wye/Delta) starter? Although I have used them before, I have always used the pre-built versions. But now I need to build one in a control cabinet.
Dave
I can only try!
Dave wanted a diagram and the site I found had one. I presume he wanted a schematic drawing of wye/delta starter. The wiring for wye or delta motors is not quite the same thing. Sorry!
Thanks Randylud
Thanks Randy
You were right, the starter is what I wanted. But thanks anyway Rsdoran, it looks an interesting site
Dave
This is for a friend. This setup worked before they replaced one of the motors. Setup as follows: Two single-phase 230V 7.5Hp 1725rpm motors...
66
16,372
Dear All, I have a machine of stone cutting CNC. with Siemens 810D system. I am very tired to maintain(Servo drive failure) it now wants to...
4,928
What happens when a servomotor is driven by another by another motor at high speed, but the servomotor itself is not power, but indeed connected...
2,224
Hi: In the plant that I am working for now there are two PowerFlex 700 VC 50 HP to control two pumps. The problem is that the 50 HP pumps were...
2,029
Hi Folks , I am in a pinch. I have a Lenze 9300 Servo Drive that is driving a MCA19S35-SCMP1 Servo Motor. The brake is bad on the Servo Motor...
3,962
