What a Kick in the A$$ this has turned into! It's
GREAT!
Ron said...
NOTE: The earth can not be "hot"
To which I say... HOT is a "relative" issue.
Take a 120VAC line... tie two taps onto it.
Connect a 500-ohm resistor to each tap.
Connect the other end of one of those resistors to a ground-rod over
here (in damp dirt).
Connect the other end of the other resistor to a ground-rod over
there (in dry sand).
Measure the current going through each line to its' ground-rod... there
will be a difference. Simply because of this difference, there
will be a difference in the potential between the connection points on the two rods.
Measure the voltage between the two rods... there
will be a potential difference.
(I know you know this Ron,... this is for the kids!)
If we make a few assumptions...
- the ground-rod in the dirt line is perfect...
- the ground-rod in the sand line is less than perfect (500-ohms)...
- the resistance between Mother Earth(1) and Mother Earth(2) is 0-ohms...
(that's not likely, but let's assume so)
- the resistance between Mother Earth(1)&(2) and the "source ground point" is 0-ohms...
Dirt
500-ohms 0-ohms
+------/\/\/\/---(A)----/\/\/\/--------- Mama Earth(1)
120VAC-------+
| Sand
| 500-ohms 500-ohms
+------/\/\/\/---(B)----/\/\/\/--------- Mama Earth(2)
At the connection points, (A) or (B), one of those rods
will be "HOT"
relative to the other. That is, of course, the very basis of electrical distribution - "potential difference".
The current in the "dirt line" will be 120/500 = 240 mA
The current in the "sand line" will be 120/1000 = 120 mA
The damp dirt will present a much lower resistance to good ol' Mother Earth than the dry sand. So the resistance in the "sand" line will be much higher, thus resulting in much lower current. The voltage at (B) will be anything but zero... your basic "voltage divider".
If "e" stands for mama earth...
The voltage at (A), that is, Vae(1), is 0-VAC.
The voltage at (B), that is, Vbe(2), is 60-VAC.
The voltage between (A) and (B), that is, Vab, is 60-VAC.
Now, be a sport, play along and take off your shoes...
Place one bare foot by this rod and the other bare foot by that rod... go "
MoooOOOOO!" You will indeed feel that warm, fuzzy feeling that we electricians (and cows) have come to know - all too well.
And, if
you can't feel it... have your wife (females in general) stand in your place... for whatever reason, she is more inclined to feel it! I'll be damned if I know why! Maybe it's the "relative" amount of "water" in a female body.
I used to work in a shipyard and a railroad car manufacturing plant. We had a lot of female welders. They were always complaining about feeling snake-bit.
If the resistance between Mother Earth(1) and Mother Earth(2) is NOT 0-ohms, then the game is further complicated. Likewise if the resistance between Mother Earth(1)&(2) and the source is NOT 0-ohms, then, again, there are more complications.
If the resistance between Mother Earth(1) and (2) is 0-ohms but the resistance between Mother Earth(1)&(2) and the "source ground point" is NOT 0-ohms, then... the potential difference between (A) and (B) is reduced! AHA! Let's just introduce some resistance between Mother Earth and the "source gound point"!
That might be better for us in the near-term... however, that resistance is using power... and I don't think the generator plant is willing to swallow that cost.
The point is, All Mother Earth Ground Points are NOT created equal! Thus, potential differences!
With respect to the URL's posted by ajbachhuber, I found the one named
"Stray Voltage Handbook" to be a very simple, straight-forward explanation of the basic problem. It is well worth the read.
Turning on the "Way Back Machine", I found a couple of really old threads talking about grounding. Interesting stuff. Also, it was nice to be reminded of a lot of old friends that haven't been around for quite a while.
Ooops! I forgot to post the url's
http://www.plcs.net/dcforum/DCForumID4/321.html
http://www.plcs.net/dcforum/DCForumID5/1588.html
There are a bunch of these in the old forum.
