Lenze MCA19 S35 Servo Motor would like to replace with another brand
Redland Brick
Mar 2005
24
Hi Folks ,
I am in a pinch. I have a Lenze 9300 Servo Drive that is
driving a MCA19S35-SCMP1 Servo Motor. The brake is bad on the
Servo Motor ,and I cannot find a replacement quick enough. Is
there another brand that we maybe able to use. AB Kinetix ,
ABB , etc. We are going to disassemble the motor tomorrow, and see
what we can do. Do you have any ideas.
Thanks in advance,
Brakes on servos are used when power is off or when the drive faults. Most of the time it is on an axis that will fall if the servo has a problem.
You may want to just look at replacing the break. You may be able to get it faster than a new motor. Sometimes putting a different brand motor on a drive can be a challenge. It depends on how the drive commutates the motor and how the feedback is done. Sometime the encoder/resolver is matched to the polls of the motor. A different brand motor may not be setup the same way.
I don't know about this servo motor specifically (nothing at the LEnze site) but brakes are usually add-on options, so you may be able to just replace the brake. Have you called Lenze?
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
82
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
238
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
182
Hello guys, I'm trying to use the Lenze GDC 4-14 with the system bus adapter 2177, but it doesn't appear in the communication window. It's like I...
231
Hi everyone. I got the endless "booting/connection" sequence on my Lenze 9400 HighLine. EZAEBK1001 Keypad is showing "question mark" while trying...
291
