Lenze 9400 not booting up
v&b
Nov 2023
Rava
Hi everyone.
I got the endless "booting/connection" sequence on my Lenze 9400 HighLine. EZAEBK1001 Keypad is showing "question mark" while trying to connect to VFD. (check the attachment)
Unfortunately I don't have any diagnostic modules like Lecom A/B.
The keypad itself works well, I've checked on another Lenze VFD.
Any suggestions? Thank you in advance!
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
179
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,087
Hi Guys / Ladies, Just a heads up! A problem has been found with the firmware (boot up times) on earlier versions. This problem manifests on...
1,771
Help Required .... I have configured the CANOpen expansion option card on the G310 to as SDO Master at 500 KBaud. There are 3 Devices. The 1st...
2,289
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
80
