Lenze 9400 EPL Woes
mjoubert
Jun 2007
Pietermaritzburg, South Africa
192
Hi Guys / Ladies,
Just a heads up! A problem has been found with the firmware (boot up times) on earlier versions.
This problem manifests on power up. EPL faults active & drives reporting system failure errors (Control Card Defective).
If you have issues with your ELP units, contact your suppliers & get them to contact Germany for an exchange.
Regards,
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
184
Hi everyone. I got the endless "booting/connection" sequence on my Lenze 9400 HighLine. EZAEBK1001 Keypad is showing "question mark" while trying...
292
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,107
Help Required .... I have configured the CANOpen expansion option card on the G310 to as SDO Master at 500 KBaud. There are 3 Devices. The 1st...
2,296
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
86
