Tia Portal V13 with Lenze 9400 Profinet problem
sohwel
Aug 2005
Kuala Lumpur
53
I try almost everything but not solve the problem.
As attached is the screenshot of the error from Tia Portal,
There seem problem with the "PZD (7W) AR cons"
If i deleted this module on TIA portal the CPU have not error, then i could not
talk to the drive from the program.
Anyone encounter this problem before?
CPU1510SP-1 PN (Siemens)
Tia portal V13
Lenze Servo Drive 9400 with E94AYCER (Profinet)
Regards
try to read this article carefully (unfortunately not ENG). https://www.lenze.com/de-de/application-knowledge-base/artikel/200804173/0/
That might be a useful stuff.
Off the top of my head... a reason might be:
  • missing of GSDML file in the project;
  • wrong GSDML file installed or it doesn't fit to the current firmware of Drive;
  • wiring issues;
  • not working hardware;
  • all together;
BR
Well... it turn out the way tia portal work with profinet is very different from step 7. Or it seem that way to me.
The PZD module actually will fault if there any fault in the servo including when there no main power.
Apparently the input and output start Address is irrelevant as the hardware identifier of the PZD is use as the a starting address when calling the fb that talk to the servo.
Thank for you help.
Regards
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,887
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,392
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM. For many weeks, was able to go online and monitor blocks while troubleshooting...
3,980
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,189
hello, i downloaded TIA portal and PLCSIM V13 trial version, i am trying to establish communication between tia portal and plcsim for simulation...
4,187
