TIA portal v13 and plcsim
kripajsw
Feb 2018
windsor, ontario
17
hello,
i downloaded TIA portal and PLCSIM V13 trial version, i am trying to establish communication between tia portal and plcsim for simulation purpose. Unfortunately its not working.
I dont have any hardware just want to learn TIA portal.
I fallowed procedure given on Siemens website, whenever i am trying to download the program its directing to device config and then not showing load option . please see the image and will be thankful if anyone can help...thanks in advance
[/ATTACH]
hello,
[/ATTACH]
What is your operating system?
Go to control panel and open PG/PC interface. What are the settings?
Hello Karthik06, welcome to the forum.
Did you follow the link? What problems are you facing?
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,883
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,390
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM. For many weeks, was able to go online and monitor blocks while troubleshooting...
3,978
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,187
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,087
