TIA Portal v13 Monitor not working
Joppy
Jun 2016
WI
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM.
For many weeks, was able to go online and monitor blocks while troubleshooting and testing new code.
Today, I can go online with PLC, but when I click "Monitoring On/Off", It does not stay on, and I can not monitor block execution.
Any idea what might cause this? I've tried uploading from PLC, re-opening my last saved project and re-downloading, rebooting,
When you go online with the CPU, in the project tree all the hardware and also all program blocks will be marked with a green dot if they match online and offline. Is this the case ?
Besides what JesperMP said, also make sure that the block you are trying to monitor is been called
Regards
Hagos
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,889
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,393
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,191
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,092
hello, i downloaded TIA portal and PLCSIM V13 trial version, i am trying to establish communication between tia portal and plcsim for simulation...
4,187
