TIA Portal v13 SPI needed
IdealDan
May 2017
MA
480
Hi Guys,
Please, I'm in need of TIA Portal v13 SP1
The V13 I saw can't open a Comfort panel HMI file.
Can any one help? It will be much appreciated!
Thanks in advance
What do you mean by open HMI file? I have a feeling the file you are trying to open can not be opened and can only be used to download to HMI
Download SP2, for all intends and purposes it is the same as the latest update of SP1.
Thanks for your response Bro;
If I create a file with SP2, can SP1 open the SP2 file?
Good question, I do not know and I no longer have SP1.
I didn't realize Siemens is removing some versions off their site that I now am getting concerned. A couple of weeks back someone was looking for 15.0 and that was also removed.
As long as this is only for a Comfort panel, there are no S7 CPUs in the TIA project, then there will be no good reason to go back from V13 SP2 to V13 SP1.
Can you describe what you want to do, details will most likely be very helpful to getting the right answers.
I want to open and HMI file, to me, is very different from I want to open a project of TIA V13.0 update 2, or something along those lines.
Then I am going to makes some changes and email the project to someone else who only has version TIA 13.0 update 2 so that he may download it the CPU with firmware version ......
Bro,
I'm working on a mini Project involving PLC & HMI; but for some reason I can't use my PC to do download where as the PC to use runs TIA Portal v13 SP1.
So, I'm looking for v13 SP1 to develop the HMI part from home to save time.
The ones I downloaded online does not have WinCC comfort software component and can not properly open program from the SP1.
Bro,
Yo brother, whats shaking,
I see. WinCC has few different versions, going by memory, basic does not include comfort panels and you would need one with WinCC advance to work with comfort panels. Professional version would also include comfort panels but again I recall something unusual about it not having something that is included with the advanced version, so better stick with advanced. TIA also has basic version which works only I don't think includes S7-300, you would need professional version.
So to summarize, and going by memory:
TIA Portal versions: Basic and Professional
WinCC versions: Basic, Advanced and Professional.
That's it Bro, you are correct!
Please, can anyone help me with WinCC Advanced v13 SP1 ?
I do not have it.
And to correct my terminology:
Tia Portal can have two components, Step7 and WinCC:
Step7 versions: Basic and Professional
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,885
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM. For many weeks, was able to go online and monitor blocks while troubleshooting...
3,978
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,187
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,087
hello, i downloaded TIA portal and PLCSIM V13 trial version, i am trying to establish communication between tia portal and plcsim for simulation...
4,186
