OLD AB PLC, 1747-L40C (well old to me, young to others)
geniusintraining
Jun 2005
SC
8,287
I have a customer that has (well had) a 1747-L40C, and drop the machine off the truck... it did not like the fall :)
So they have a paper print out of the program that I am going to type in and they want to go back with the SAME (not broken) CPU and I was wondering if anyone could tell me what is the difference from the L40A B and C and I also think they have an L??
They do not want to upgrade as it was a contractor that dropped it and is now paying for the replacement, so just doing what the customer has asked for....
I could not find anything or not much on AB but I think it may be due to the age?
Thank you very much...
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1747-um009_-en-p.pdf
It looks like the...
-1747-L40A has (24) 120 VAC Inputs & (16) Relay Outputs
-1747-L40B has (24) 120 VAC Inputs & (16) Triac Outputs
-1747-L40C has (24) 24 VDC Sinking Inputs, High-Speed Counter Input & (16) Relay Outputs
-1747-L40E has (24) 24 VDC Sinking Inputs, High-Speed Counter Input & (16) Transistor Sourcing Outputs
-1747-L40F has (24) 24 VDC Sinking Inputs, High-Speed Counter Input & (16) Relay Outputs
-1747-L40L has (24) 24 VDC Sourcing Inputs, High-Speed Counter Input & (16) Transistor Sinking Outputs
-1747-L40P has (24) 240 VAC Inputs & (16) Triac Outputs
You're welcome.
BTW I found that manual by searching for "SLC fixed hardware style" in the google search bar at ab.com in the upper right corner of their home page. Sometimes I have better luck there than in the literature library, especially for obsolete stuff.
Paul
im working on an old steam generator which has a old slc500 1747-L40A processor which has shorted out and several outputs are light up but have no...
3,286
82
118
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,100
Hi everyone, I have received request to troubleshoot an old Bosch device. Bu t I'm not familiar with it. Anybody know how and which software I can...
883
