Old HMI replacement
qwemx
Jul 2017
Earth
195
I have been asked to help with this issue there is an old HMI which has to be replaced as it takes too long to load a replacement was ordered and now we have a new HMI from Schneider which is already programmed but the older HMI has a weird connector and the new one does not have this Interface.
OLD HMI :Modicon XBTF034510
NEW HMI : SCHNEIDER ELECTRIC Harmony GTO Model HMIGTO5310 (Ethernet,RS485)
PXL_20230324_125448463.jpg PXL_20230324_125457168.jpg PXL_20230324_125422275.jpg PXL_20230324_125439928.jpg PXL_20230324_124349235.jpg
On panel side picture it shows that panel tryes to commuicate (led on coms) so is panel screen broken?
Also is it checked that PLC additional communication PCMCIA card isn't broken.
It can be also normal modbus or Fipio way, but you can only check from PLC program or from PCMCIA card markings which communication module it really is.
I haven't used fipio at all, so I can't help much.
Have you checked that all other Fipio equipment works there?
Hi, I am required to upload an application from a Panelview 700 HMI which the client is worried will fail or break quite soon, and download the...
6,954
Hi Guys, Hoping we still have some Siemens Old hardware Gurus on here. We are trying to support one of our long time customers. Who have obtained...
925
We have a customer with a very old piece of equipment (circa 1999). That has a OP7 Siemens HMI unit. Their current unit has gone down, and are...
6,259
Hi all, I'm hoping someone out there may have had experience with an MCGS branded HMI. This company is based out of China and makes a fairly...
19
14,333
I have a Mitsubishi FX-25DU-E HMI that I need to get into. From the looks of it I need fx-pcs-du/win-e to talk to it. It appears the software is...
1,318
