Siemens OP7 OLD Hmi Terminal
exiled
Jun 2002
England
131
Hi Guys,
Hoping we still have some Siemens Old hardware Gurus on here.
We are trying to support one of our long time customers. Who have obtained a machine we manufactured some 25/30 years ago.
Plc is S7-200 with no problems.
Problem is the Hmi is an old OP7. All in Russian.
I have the WinCC file that was converted from Pro Tool (but not the Pro Tool file).
I cannot for the life of me establish comms with my PPI or MPI cable.
Am i Missing something or am i doing it wrong.
Regards
I did some work on those panels back in a previous job. When they would lose their program. I could reload it with a compactflash card. You can't use any card, you have to use a Siemans one. Upon booting the panel if it see the card, it prompts to copy it to memory. Once done the card can be removed.
Don,t know about OP7 panels but with OP17DP 12 tekstbased panel ( more or less the same Family then the OP7) you transfered the Projectfile with protool software using a serial cable ( db9 at pc side and db15 at hmi side). But on the OP17DP12 HMI there are 2 Ports availible( db9 port for profibus communication with plc and db15 port for project transfer).
Regards
Henny
What is the part number of the OP7? There were 3 variants - 1 of which does not have MPI/PPI communication capability to S7.
6AV3607-1JC00-0AX1 - OP7/PP - cannot communicate with S7
6AV3607-1JC20-0AX1 - OP7/DP - can communicate with S7
6AV3607-1JC30-0AX1 - OP7/DP-12 - can communicate with S7
Transfer cable is Rs-232, part# 6XV1-440-2KH32
For the 2 models that do have S7 communication capability, you use a cable with the following pin out (S7-200 to interface IF1B on the OP7):
3 - 3
5 - 5
8 - 8
Profibus cable and connectors would work.
If this machine is going to kept for a longer time, I recommend an upgrade to S7-1200 and Comfort or Comfort Unified HMI.
We have a customer with a very old piece of equipment (circa 1999). That has a OP7 Siemens HMI unit. Their current unit has gone down, and are...
6,247
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
942
I have a customer who had a faulty Siemens OP7. They sourced a replacement. They have the original program. I downloaded the program to the...
2,532
dear friends, kindly guide me how to download software for op7,op77 if possible give the link.
2,390
Hi i Have an OP7 [6AV36071JC200AX1] and a CPU s7-315 DP [6ES73152AF020AB0] I'm communicating between the two via DP, i need to set up the CPU so...
1,403
