Old Koyo SA-10R PLC
emorym
Apr 2004
South Carolina
I have a piece of equipment here that is operated by an old Koyo
SA-10R PLC. When it was purchased the supplier did not provide the internal logic to the PLC. Anyone have any suggestions as to how I might obtain this information from the PLC? I do not have a programming panel of any type for this unit. I plan to replace it this summer and I need to know the logic in order to program the new one when I install it.
Out of pure bordom and coursioty, I did a number of searches for about 45min looking for some info on your part no. All I could find was on Koyo's support page (all in Japanieese). Just no luck.
As you may know, AutomationDirect's parent company is Koyo. Why dont you give them a call and maybe they can point you in the right direction.
Good Luck with it.
Mike.
Old Koyo PLC
I had contacted Automation Direct but without success. After your suggestion I went a little further and contacted Koyo Japan. They have been able to help me. I can us Koyo's D3-HPP to access the internal logic of the old PLC. Koyo Japan also had an old manual for the SA-10R. They sent one of them to me. I already had a high opinion of Koyo before this and now it is even higher.
Thanks for your input.
emorym
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
107
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
147
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
257
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
105
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
321
