Old Net Eni network
kirk
Jul 2003
Houston
71
I have a simple question I’m kinda embarrassed to ask.
If I have a micrologix 1500 on a net eni.
Can I replace my Ethernet switch with a WiFi Router ( https://www.gl-inet.com/products/gl-ar750s/ ) and get wireless access to the plc?
Can it be that simple?
The goal would be to be able to program the PLC as well as run a run time license (single station) for an RSView / FactoryTalkView program without running Ethernet cables.
As long as the PLC is on the "LAN" side of the wireless Access Point, rather than the "WAN/Internet" side, you can definitely do this.
That little travel router has 2 LAN ports, and 1 WAN port.
If your Ethernet switch has an available port, I would just connect one of the WiFi Access Point LAN ports to it, rather than removing the Ethernet switch.
I have done that permanently and temporarily.
In a waste water treatment system, that had 6 control panels networked together, in one panel i added an old WiFi router that I could connect to and get online with all the PLC's and the networked HMI's.
For other lines I carry around a cheap Amazon WiFi router my laptop knows and hook it to the lines network switch. I would follow Ken's advice and not replace the switch with a router, just add onto it. And if the switch doesn't have any open ports unplug one of the existing cables and plug it in one of the router ports.
Hi, I'm not a siemens expert but we recently converted an old siemens PC into a virtual machine so we could run it on modern hardware. It was...
7,835
hello, I would like to use an AB Micro820 PLC to control an SMC manifold. it will be the EX600 ethernet coms module with 7 valves and a 16...
1,571
I'm running a distribution terminal on ControlLogix 5580. It's been stone cold where we are and we haven't run some of this equipment since being...
2,434
Have a machine in one of our plants that has a SMC EX260-SEN1 ethernet manifold. Has anyone used one of these?
3,790
My DeviceNet skills are rusty and weak... so of course, an old, obsolete Reliance 400 HP VFD goes down and we're looking at replacing it with a...
5,001
