old Omron C200hs network
navidebo
Oct 2010
Brownsville
Hi experts, I need make a network with 80 old plc's omron c200hs , the rs232 port is connected to Nt21 screen , I red my option is connect some converter from peripheral port to any converter to rs485 or ethernet,
The idea is get data and monitor each plc with a computer and then save data to Sql server.
My questions is :
Is possible make a network with these old plc's ?
what hardware(converters) i need to get this work ?
I red a need to use Kepserver to get data from the network.
apreciate your help.
My questions is :
Probably the best way would be to use Omron's Controller Link. I believe the correct cards for the C200HS Series would be C200H-CLK21 Cards. For this to work, you will need an open Slot in each Controller Chassis. It is possible to do Ethernet, but I wouldn't recommend it with the C200 Series. For SCADA, the best way to go would be a CS1 Chassis with an Ethernet Card and however many CLK Cards you need. This way you can break it into Segments that make sense. I forget how many you can put on one Network, but it is at least 32, but probably more than that.
Go to http://www.omron247.com and Download the manuals for C200H-CLK21, CS1W-CLK21, CS1W-ETN21. You might have to sign up to get some of the manuals.
Stu....
Project involves updating a ~23 year old controller (C200HX CPU64). The HMI is a windows NT machine with the gui done with Delphi 5 (Pascal)...
1,103
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
1,998
Hello guys, Can someone advice what software do I need to open an old Omron CPU41 PLC project?
1,949
I am learning mnemonic code for a Omron Sysmac S6 PLC. Is my code below right to get it like the picture? 000 LD 0 001 AND 1 002 OR 2 003 OUT...
1,336
Hi, I've been asked what is involved to upgrade and old CQM1-21 Omron PLC to a CJ2M. I have the old file with an extension of .cdm and searches...
1,581
