Old panelview plus 400 with Compactlogix L32E
elya97
Feb 2022
morocco
Hello .
Info: Panelview plus 400 2711P-K4M20D
Compactlogix 1769-l32E
i make a program in RSlogix 5000 and Factorytalk view for HMi, i download the .mer file to PanelView and the program to plc
but i want to communicate the panelview with Compactlogix with ethernet and she didn't works
if you have any help I will greatly appreciated your help
Hello and welcome to the forum. For future reference, please try to explain what isn't working. What are the error messages you are seeing? Including screen shots helps a lot. "It doesn't work" doesn't give us much information to try to help you.
In FactoryTalk View software you need to create a Device Shortcut to your PLC. This is done in View Studio by accessing RSLinx Enterprise (in newer versions it is called FactoryTalk Linx). If you've gotten as far as creating the .MER file then I am guessing you have figured out that you need to do this. But what most people miss is that you need to copy the Design configuration to the Runtime configuration.
The Design tab is where you configure how your computer will communicate with the PLC during development of your application.
The Runtime tab is where you configure how the PV+ will communicate with the PLC. Usually, your computer and the PV+ will use the same method (such as Ethernet) so they have a button to copy your design configuration over to the runtime configuration. Click on that, apply your changes, click OK to close that window and then re-create your .MER file.
OG
OG
Thank for reply
for more info :
i add device shortcuts and i copy from design to runtime . i creat runtime (.mer) application with the same firmware 5.10 . i download it to panelview
for communication i use ethernet straight through cable
my compactlogix ip is 192.168.1.11
255.255.255.0
my panel view 192.168.1.13
255.255.255.0
192.168.1.230
my laptop ip (TCP/IP) 192.168.1.230
255.255.255.0
communication between laptop and plc : good
communication between laptop and panelview: good
communication between plc and panelview : not work
OG
some pictures :
https://ibb.co/myr5Vy9
https://ibb.co/Tg8RVWz
https://ibb.co/py58Q86
If you need any more information, I'm ready
when i run the application in panel view nothing works the buttons are not responding and gives me error message
Thank you for the added detail. You mentioned the straight through style ethernet cable....I am assuming you are connecting through an Ethernet switch of some sort rather than directly connecting the PLC to the PV terminal.
When connecting directly, it is usually necessary to use a crossover cable instead of a straight through cable. Some devices can detect if you are connecting directly and adapt so that you can use either cable type. However not all devices support this capability. Most computers sold in at least the last five years support this. But, I don't know if the devices you are using have this capability. If you are connecting via a switch then it is not an issue, but if you are connecting directly I would suggest using a crossover cable.
Assuming that is not the issue, are you able to use the Test Application feature to run the application on your computer? Does it work there or does it give you errors?
OG
EDIT: I just looked it up and the CompactLogix and the PV+ do not have this feature. It is called Auto-MDIX. So connecting these devices directly would require a crossover cable. But when you plug your laptop into either one, any cable would work successfully.
OG
yes this is what i notice , you right
some picture:
https://ibb.co/F05JKT8 between plc and panelview
https://ibb.co/TRW2rqh between plc and laptop
https://ibb.co/CMSMP6h cable what i need
if you notice no led on between plc and PV+
i will make this cable or buy it
i will update any news. thank you sir for helping me
adit: what about panelview ip that i have it is ok with plc?
Glad I could help! Yes, the IP addresses look good.
If you have an Ethernet switch available you wouldn't need any new cabling. It doesn't have to be anything special. An inexpensive switch will work just fine for testing purposes.
OG
OG
Which ethernet swtich would you recommend me to buy it. because i don't have information about that
Any Ethernet switch that is readily available. I'm not sure what you might have available locally. But for simple testing purposes I would not spend more than $20-30 US dollars. Something like this (Amazon link)
But that would really only be for testing purposes. Something I would keep in my bag or at my desk. For a production system, get the crossover cable or look into an inexpensive switch rated for an industrial environment. Phoenix Contact, Moxa, Rockwell (Stratix 2000), and many others make these types of switches. These are all much more expensive though.
OG
OG
thank very much sir . that was very helpful
it works now . i change cable diagram manualy from straight through ethernet cable to crossover ethernet cable and it work now
Hi All! Is it possible to establish any remote access on PanelView Plus 2711P-T10C4D6 (logic module 2711P-RP6)? This panel is running WinCE 4.10...
1,859
Good Afternoon , I have 3 old Panelview Terminals that I need to replaced. Could you tell me the replacement for the Panelview Terminal 600...
1,885
Good Morning , I have several Panelview Plus 700's off of old machines. I would love to use these for small machine upgrades around the...
2,289
Hi all, I'm starting a project where I have to convert an old HMI to work on a new panelview plus 7. A person who used to work for us, but does...
2,848
Good Afternoon , I have a project that I am getting ready to do to change over an old Panelview HMI over to a Panelview Plus 1500. I forget ...
17
4,755
