Hello,
One of my colleagues were at a plant were we have two old Siemens 314s running on identical seperate processes. He did a minor modification on both, but could not test it properly because the equipment was not operational.
Afterwards the customer is telling us that there is a false reading on one of the plcs. We suspect the my collegue forgot to load a network in the plc that has the reading failure.
To have this verified we swapped the EEPROM from the one working, rebooted power, but it was still faulty.
We swapped the cpus and the reading was ok. So, swapping cpus with same EEPROMs as when programs loaded, everything was ok. But not when using the EEPROM from the one working.
It tells us that when we swapped the EEPROMs, it can not have been using the program from the EEPROM working.
Therefore my question is: What is the proper way to boot from an EEPROM?
Does the 24 voltage have to be turned off over a certain period in order for the RAM to loose the previous program? Do we have to do any procedure with the operator key while there is no EEPROM in the cpu?
Any suggestions on this would be highly appreciated
brg
Andreas
brg
Andreas
