Old Step5 Cpu115u Problem
dj_adamix
Jun 2014
Canada
Hello
i have an old CPU115u system with few I/O cards.
Got it connected, but no matter what i do i cant get it to RUN.
It always flashes error RED.
I believe i need a IM or termination resistor connected.
Does anyone know exact pins on the IM connector where i can connect the resistor?
Should i use standard 120Ohms?
Adam
Hi, and welcome to the forum!
If you use only the main rack, you don't need an IM.
But there must be a latch between 2 points on the rightmost terminal reserved for the IM.
I think the latch was on place no 11 on the outmost sockets, but don't latch until you get it confirmed (I've got a memory leak ;) )
Kalle
Yes ! Now does anyone remember exactly which pins need to be latched on the IM connector. ?
Thanks for the manuals, but believe me I already exhausted my resources before posting on here. All siemens says is to buy a resistor module. I know there's a way to just jump the IM or use a normal resistor instead.
Anyone ??? !!:)
Kalle
Here it comes "fresh" from the siemens site:
Quoting:
"terminator has a bridge between the connectors d30 and z30 and will be connected to slot of the interface module."
The original latch is a cupper connection in a nice plastic holder.
I can recall that we just used a molested paper clip on our lab rack.
Kalle
Edit: The link:http://support.automation.siemens.com/WW/view/en/13983231
See also the page 637 in the manual that moggie linked to.
Kalle!
Youre awesome!
THank you so much! i dont know how you found this but ive been searching google and siemens forums for two days now and couldnt find anything.
Your jumper works perfectly. CPU is in RUN mode!
Thanks again!!
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
134
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
231
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
100
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
307
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
86
