old TI 305 programming
tommy23t
Nov 2003
New Jersey
136
Hi all,
Working on an old TI 305 plc installed on a machine, trying to troubleshoot. I am using the manual for the 305 from Automation Direct for the most part, but have many "SR" coils - set and reset in the logic.
Example- CT623 = K9 -------- SET (SR412)
The manual calls out for shift registers, but there are none configured in the classic style. Could these be some "special relay"? If so, do they differ from the "C" relays? These are used in the logic to set or reset as a count increases to a specified level.
Any explanations appreciated.
Thanks, tommy23t
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
58
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
141
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
243
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
102
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
313
