Omron Analogue Unit MAD01
Oct 2012
100 Vesivesi RD kinoya
Hello veryone
Could somebody assist me with trying to program my MAD01 analogue unit with a CPM2A controller.I have a W353-E1-1 programing manual which I followed and these where Iam.
I wire my input of 0-10V in the input one terminals and used a current output.I am using range code FF04 Which what I WIRED
I use the lader logic example that was given by the manual to write code and move inputs to the final outputs.
I think I am missing something which is to do with register or memory.
After tansfering and running I still could not get my output.
when I vary my 0-10volt input.
Your help will greatly appreciated
If you would ZIP your Omron program and post it here, someone may be able to help. If you can make a screen print of snapshot of the part that you have problems with, that would be a starting place.
Hello everybody , Can anyone guide me how to do 4-20 mA analogue input in CX- programming. I do digital I/O programming before but i never do...
2,485
Hi there, PLC in question: 240VAC Omron CP1E-NA20DR-A Features: 12 inputs – 2 of which analogue, 8 outputs – 1 of which analogue My question is...
19
18,959
Hi guys, I was wondering where can i download the Omron analogue manual, i looking for the CJ1W-DA021 & CJ1W-DA041. Thank you! for the support...
1,841
Hi all its me again!! Omron AD081 I am using an Omron ADo81 analogue input card. And i have read the manual inside out. I cannot understand the...
6,945
Hello all and thanks for looking at this post. I'm having trouble with an Omron CJ1W-MAD42 4 input 2 output analogue unit. I have set up the...
7,267
