Omron CJ2M analogue input
minaykha
Apr 2009
singapore
96
Hello everybody ,
Can anyone guide me how to do 4-20 mA analogue input in CX- programming.
I do digital I/O programming before but i never do Aanaloge I/O.
I need to use 4/20 mA as input and need to creat alarm when alarm set point is trigger.
Thank in advance.
The analog input will generate a proportional value in a CIO word. What value you get and what CIO word it shows up in depends on what module you use and the module settings.
For example, a CJ1W-MAD42 set to module 00 will generate an input value in CIO word 2005 of 0 to 8000 decimal over a range of 4 to 20 ma.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
67
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
120
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
233
