Omron and Devicenet
Boyko
Oct 2005
26
Hello
When an error occurs in a devicenet, my CJ1W DRM-21 displays the unit number which has a problem and an error code. I'd like to display that unit number on a HMI, but I can't find where it is located.
For ex. I have 4 devices and unit No 3 has a problem. I want to display that. On what adress 3 is placed.
Manual #W380 will be a lot of help to you.
There are status words associated with the module that will give you the information you are looking for.
The information is in Section 3.
Hope this will help.
G'day All, Having some trouble with an omron devicenet network with nodes going into bus fault. CPU is a CS1G with a DRM21-V1 devicenet maser...
1,891
Hello Everyone, I am trying to setup/debug a devicenet network, but can find where the variables have been setup. The Sysmac manual mentions...
1,091
History: On an Omron CJ1W-DRM21 Network, had a servo driven actuator that went bust. This node is in the middle of the memory map (node 6), with...
1,757
Hello forum members, We are having a frustrating issue (yet again with my favorite network - Devicenet). We have an ABB robot that works with an...
4,038
Hi I am working repairing some old machines, 3 omron an 1 AB using devicenet, there is a CP1H with a CJ1W-DRM21 as master in node 63, two CPM1A...
1,525
