Omron C1000H Memory Error
Hoosierdaddy
Dec 2007
Indiana
I have an Omron C1000H CPU in fault for "memory error". I first re-seated the memory module (C2000-MR34-V2) and re-loaded the program. I cycled PLC power, and the CPU immediately faulted again with "memory error". I then replaced the memory module with a new one, again loaded the program. Still no change. I then replaced the entire CPU module to no avail.
I'm stumped at this point, and need some advice on where to go from here.
Thanks!
does any one know how to get around an unknown password for a omron c1000hcpu01e2 used using the programming module clr--monitor--clear does...
1,964
Hi Friends, We are facing CPU ERR problem in the Omron PLC of Model C1000H. Anybody can suggest me to resolve the problem. Regards, K.Vajravelu
1,937
I'm working on a Omron C1000H that has a RS232 card C500-LK203 mounted to it. When I try to connect using SYSWIN it allows me to connect but says...
6,021
Guys, my client has an Omron C1000H PLC programmed using CX-programmer. Every time he has a power dip the PLC has to be manually (via software)put...
4,224
