Omron PLC Model C1000H
K.Vajravelu
Feb 2008
Hi Friends,
We are facing CPU ERR problem in the Omron PLC of Model C1000H.
Anybody can suggest me to resolve the problem.
Regards,
K.Vajravelu
Could be one of many different problems.
You need to connect a programming device to determine the error.
Once you know what the error is, someone may be able to help you correct it.
Hope this will help.
With no display on the programming console, we are really guessing at the possible problem.
First thought is that part of the power supply may be bad.
Second thought is that the cpu may be failing.
I would make sure the memory board is fully seated.
Also check that all I/O modules are fully seated.
Many of the errors seem to be related to I/O.
Hopefully you have a back up of the program.
I have not been much help. Good Luck.
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
138
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
121
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
191
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
113
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
220
