Omron C200 H- RT201
kalabdel
Feb 2015
Ontario
1,108
Hello everyone,
I have a system that I believe consists of :
-CS1H-CPU66H with Io modules connected to it.
- Two C200H-RT201 with a bunch of ID212 and OC226N I/O modules connected to them
I uploaded the program off the CS1H and it looks like it had a program running only part of the equipment which means that the other two C200H controllers must have the other parts of the program running the rest of the equipment. But I couldn't find a port on the unit where I can plug a programming cable. The only door I found o the unit has a set of dip switches and no port (see picture).
So, what's a C200H-RT201?
Kal
A remote receiver. It is connected to the PLC through an RM201 on the rack. You cannot connect to it - the connection is done at the PLC. The system runs on a twisted pair screened. If I remember correctly the I/O appear in the channel 100 odd range - been a long time though. These are basically dead - no longer made or supported.
Thanks Bob, I couldn't find much in the form of documentation online and now I know why and where to look.
Cheers
Kal
Hello, Kindly help me on this PLC-scada issue. Newbie here. We're on the ship and our scada PC (IPC APAX-5571) suddenly won't boot anymore (no...
5,842
Hello, I'm trying to get program from running C200 CPU Omron, with LK201 Host Link. But when install LK201 on CPU, ready led is lit for a while...
2,064
Can anyone help me with setting up an ISA Co-ax PC card which is Omron Sysmac Link to C200HS CPU31 I have the card driver etc and have modified...
4,499
Has anyone ever seen a document showing a cross reference from the C200/500 mapping to the CJ1/CS1 mapping? I know there is some overlap in the...
4,475
Am performing online editing of PLC code using Syswin, when modification is downloaded, error message :Syswin Communications Error C-Mailbox error...
5,963
