Omron C200 using Syswin
scottmurphy
Oct 2004
363
Am performing online editing of PLC code using Syswin, when modification is downloaded, error message :Syswin Communications Error
C-Mailbox error 02
(CMD:4C) pops up and prohibits online edit function, does anyone know what I coule be doing wron? have uploaded program and modified from there couple of times, and verification comes up ok also. Have made quite a few mods already.
I am pretty sure that it was in monitor mode as I have done previous mods, and then it stops me at a certain point. Is that error message related to it not being on monitor mode?
I need to know the relevance of that error message to find out what I have done wrong.
More than likely the program is full, will have to do a check on that, cannot be more than 128 elements in online edit as am duplicating existing code, just changing address's. Makes sense though, as it would not even let me add on NO contact into a rung, where previously I had added an hour counting routine which wasa bit more detailed than one contact.
Will have to see if I can increase the memory size.
Well have a look tomorrow, is a few ways i can possible streamline whats there, few things that do not need to be the way they are. Thanks for you help.
FYI,
The PLC was a CPU42, memory size of 7.2kb. Current program is 7236 I think, so confirmed with local omron rep that what I was looking at was the memory size. Have given back to client to decide what they want to do, either processor upgrade, or backplane and processor to give ethernet capablilty.
Where did you find your info on the error codes?
Hello, Kindly help me on this PLC-scada issue. Newbie here. We're on the ship and our scada PC (IPC APAX-5571) suddenly won't boot anymore (no...
5,843
Hello everyone, I have a system that I believe consists of : -CS1H-CPU66H with Io modules connected to it. - Two C200H-RT201 with a bunch of...
1,547
Hello, I'm trying to get program from running C200 CPU Omron, with LK201 Host Link. But when install LK201 on CPU, ready led is lit for a while...
2,064
Can anyone help me with setting up an ISA Co-ax PC card which is Omron Sysmac Link to C200HS CPU31 I have the card driver etc and have modified...
4,499
Has anyone ever seen a document showing a cross reference from the C200/500 mapping to the CJ1/CS1 mapping? I know there is some overlap in the...
4,475
