Omron C200H PLC Problem
Anayat Ali
Oct 2009
Peshawar
I have an Omron C200HE-CPU42 PLC with some I/O cards. There is a problem in the C200H-ID212 card. during PLC normall run the PLC gives fatal error and stopped. When i check the error log in PLC it gives 00C0 error code i.e. I/O bus error. in the PLC memory when i check the IO address its bits were ON/OFF randomly even the inputs were not attached to the card. this the 2nd time i have changed the card. Can any one help me in this reagrd.
I had an iffy problem with one of these once having spurious inputs and outputs... I changed the backplane... problem cured. Try a new backplane if you have one.
s.f
Thanks for ur reply.
I have no backplane at this time but i will try to purchase it. But i have replaced the card with a new one and the machine is running. If any other suggestion kindly tell me. Thanks
Hello All, Just a bit of an issue, i have a omron c200h plc on site that controls some important machinery, the past month or so it has been...
2,743
hi!!! what is the replacement for Omron C200H-CPU01? and can you provide me datasheet of the replacement model... thanks... God Bless
7,544
We're having extreme difficulties getting the PLC to recognize the High Density Output Module (C200H-OD218). We're using SysWin 3.4 for...
11,472
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
715
