omron c200he plc error..
ajay34
May 2010
klang
249
hello all...
i would like to ask help or suggestion on problem me facing on omron c200he plc..
i had mounted addtional output unit od215 to output rack as set the chanel number 8 and 9 (new) and also set i/o rack.
as soon switch oon power the error light on cpu is blink and massage as i/o error.
what could be wrong ..can any 1 help or gv me hint
attach is pic of the plc and errors
hello gclshortt...
if i at the new it would be max..currently it have 8 and 2 empty slot .when i add 2 more or even 1 the plc show error ..
The number of special cards has nothing to do with the back-plane or slots available. On the C200HE-CPU42 you can have 10 high density cards on the system. Count the maximum cards that you have.
Regards,
See below for information on the E7 error from the W303 manual.
Once this is cleared, you will most likely get an error that you have too many Group 2 I/O modules, as gclshortt has explained.
i had count the unit not max yet.it only 7 unit been used ..
by the way how to clear i/o table and register the table again ..i had try many .
does this mean i need to add more rack in order to archive it .??
Hello..all i have 1 project to upgrade C200HE to CQM1 omron plc ..need expert suggestion been told to change old model to CQM! model ..which i...
3,746
hello sir .. i have queestion to ask ..regarding omron plc units ,, recently .i wanted to connect omron PLC unit (c200he to HMI) which locate...
2,965
dear all... i would to know..does omron c200he plc..can be support by etthernet.. i wanna commnicate omron plc with wincc but using ethernet...
2,802
Hi, I wish to connect to the OMRON C200HE PLC via its peripheral port, using omron's RS-232 interface adaptor. I have no ethernet module for...
5,485
Hi! I am having a problem with the C200HE. It has a SRM21-V1 communication module with SRT1-ID08 remote input module. I think the protocol used...
1,655
