Omron PLC c200He cpu 42
ajay34
May 2010
klang
249
hello sir ..
i have queestion to ask ..regarding omron plc units ,,
recently .i wanted to connect omron PLC unit (c200he to HMI)
which locate more than 5mtr between HMI and PLC..estimated about 15mtr long ..previosly this plc is not connected to PC or HMI..but now they wanted to connect to HMI ..
i would to know what is things i need to connect to PLC and HMI .r can i use
XW2Z-500S-V this cable to to connect?
15 metres is too far for an Rs232 serial connection - you will need RS232/485 converters.
Hello..all i have 1 project to upgrade C200HE to CQM1 omron plc ..need expert suggestion been told to change old model to CQM! model ..which i...
3,751
hello all... i would like to ask help or suggestion on problem me facing on omron c200he plc.. i had mounted addtional output unit od215 to...
1,799
dear all... i would to know..does omron c200he plc..can be support by etthernet.. i wanna commnicate omron plc with wincc but using ethernet...
2,805
Hi, I wish to connect to the OMRON C200HE PLC via its peripheral port, using omron's RS-232 interface adaptor. I have no ethernet module for...
5,487
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
27
