OMRON C28 Instruction
recycled_mind
May 2007
Cebu, Philippines
118
Please help anybody knows what is FUN98 instruction for OMRON SYSMAC C28? I need to convert this instruction to be loaded to the new SYSMAC CPM2A. I'm in the process of converting the old program of C28 to CPM2A.
RECV
Is there some sort of serial device attached?
Far be it for me to be correct, but if nothing connected to any serial port, then more than likely, the instruction is not needed????
First of all, is this a C28K or C28H?
Based on the instruction manuals for both units, Fun 98 is not defined. Additionally, these processors do not support expansion instructions.
In theory, this processor should be in an error condition due to an invalid instruction.
Sorry to not be of more assistance.
Here is the Mnemonic code for the C28 Program:
LD 2
OR 500
AND NOT 1007
AND NOT 507
OUT 500
LD 2
OR 508
AND NOT 1009
AND NOT 507
OUT 508
LD NOT 4
AND NOT 500
AND NOT 508
TIM 0 #0010
LD 1813
FUN (98) 15
LD 2
OR 1815
OR 1500
OR 1
OUT 1807
LD 1500
OR 1002
AND NOT TIM 1
OUT 1002
LD 1002
TIMH (15) 01 #0010
LD 1002
LD 1005
CNT 11 #0003
LD 1002
LD 1005
CNT 12 #0004
LD 1002
LD 1005
CNT 13 #0005
LD 504
AND CNT 11
LD 505
AND CNT 12
OR LD
LD 506
AND CNT 13
OR LD
OUT 1003
LD TIM 05
AND NOT 1003
LD 1010
AND 7
AND NOT TIM 2
OR LD
LD 1010
AND NOT 7
AND NOT 1003
AND NOT 1500
OR LD
LD 507
AND NOT 7
AND NOT 503
AND NOT 1003
OR LD
LD 507
AND 7
AND NOT 503
AND NOTTIM 02
OR LD
AND NOT 500
AND NOT 502
AND TIM 0
LD 504
OR 505
OR 506
AND LD
OUT 1010
LD 4
OR 1010
OUT 501
LD 7
AND NOT 507
AND 1500
LD 7
AND 507
AND 1006
OR LD
LD 7
AND 1004
OR LD
AND NOT TIM 2
OUT 1004
LD 7
AND 1004
TIMH (15) 02 #0010
LD 1003
AND NOT 501
OR 502
AND NOT 8
OR 6
OUT 502
LD 502
OR 1
OR 2
OUT 1005
LD 507
AND 1003
LD 507
AND 1006
OR LD
AND 501
OUT 1006
LD 502
TIMH (15) 04 #0020
LD TIM 04
LD 503
AND NOT 9
OR LD
OR 6
OUT 503
LD 3
TIM 05 #0005
LD 10
AND NOT 11
AND NOT 12
LD 504
AND NOT 505
AND NOT 506
OR LD
OUT 504
LD 11
AND NOT 10
AND NOT 12
LD 505
AND NOT 504
AND NOT 506
OR LD
OUT 505
LD 12
AND NOT 10
AND NOT 11
LD 506
AND NOT 504
AND NOT 505
OR LD
OUT 506
LD 5
OR 507
AND NOT 6
OUT 507
LD TIM 5
OR 1007
AND NOT 12
OUT 1007
LD NOT TIM 5
AND 1007
OR 1008
AND NOT 2
OUT 1008
LD TIM 5
AND 1008
OR 1009
AND NOT 2
OUT 1009
LD 1813
MOV (21) #0005 DM 32
MOV (21) #0005 DM 33
END 01
We still need to know if this is a C28K, C28P or C28H.
Based on the 4 digit addresses I would guess it is either a
C28K or C28P, but we really need to confirm this.
If it is a K or P processor, FUN 98 is not a documented instruction.
Try removing it from the program and see what happens.
Here is a link to the C**K Manuals
Its a C28P PLC. I am not so sure if this is really the actual program on the unit. I'm still waiting for the cable so that i can verify it. Thanks for help.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
154
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
104
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
140
