OMRON C40H: Communication settings
Marsupilami
Jul 2004
124
Hello All,
I have found an old C40H OMRON PLC and want to use it in a home project. since i never used a omron PLC i looking for some advice on establishing communication between the programming software and the controller.
I got the syswin 3.4 programming software and have used the diagrams i found in the manual to create a serial cable.
But now i come to serial settings and i have no idea wich settings i should use, also the PLC still has a program so maby the settings are changed(don't know if thats possible).
Can anyone give me the procedure to clear the PLC?
And does somone know the default communication setitngs for a C40H PLC? Baud, Unit, Protocol?
Regards,
Marsupilami
Omron manual numbers for that series of product is
W175 Programming manual, W176 Hardware manual.
You can download the manuals from:
www.omron247.com, search the Document Library
for the manual numbers.
Also, on that product, pin 7 is signal ground
not pin 9. Check to see how you have that connected.
Hope this will help.
Hello, I have an old C40H PLC here from omron and have found the correct programming software Syswin 3.4. i can communicate with the PLC and...
3,212
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
108
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
258
