Omron C60 K PLC Upload
Mizery
Mar 2010
Missouri
I am trying to connect to a C60 K Omron PLC to upload the program.
I have:
- Host Link 3G2C7-LK201-EV1
- RS232 Cable to connect to the Host Link to my serial port
(COM 1)
- SYSWIN 3.2
I tried every baud setting I could and I still cant upload. There were a few postings a few years ago about this problem but nothing conclusive.
The RS232 cable is a "Null Modem" cable. If you are using a "Straight Thru" cable it won't work. See this link.
Link:
http://forums.mrplc.com/index.php?showtopic=8438
A link for cable info.
Link:
http://forums.mrplc.com/index.php?autocom=downloads&showfile=73
And some more cable info, post #2.
Link:
http://forums.mrplc.com/index.php?showtopic=769
See this link for some more info.
Link:
http://forums.mrplc.com/index.php?showtopic=14494
And here is the link for the manual from post #8.
Link:
http://forums.mrplc.com/index.php?autocom=downloads&showfile=215
And another link that may or may not help.
Link:
http://forums.mrplc.com/index.php?app=core&module=attach&section=attach&attach_id=1866
Thanks!
I have downloaded all the material.
Is LSS the software I need to use? I tried to download but I recieved and error it couldnt find a file which is located in the same folder.
I dont know about LSS software. The Syswin Ver. 3.4 has that PLC listed as CxxK. Your Syswin Ver. 3.2 probably has it listed that way also. I hope you are using a Real Physical RS232 port and not a USB to RS232 adapter, sometimes USB to RS232 adapters cause problems with old software.
It does, I tried to connect by setting the CxxK. would you know what the baud rate is set on the back the the HOST LINK? I changed the baud rate on my PC to match what is set on the HOST LINK and "no joy". Do you know what the baud rate might be set at on the PLC itself or is the baud rate set by the HOST LINK?
The baud rate is set using DIP switches at the back side of Host Link unit. There is also a sticker explaining the DIP switch pin settings. See the attached pdf
Hope this helps,
SVN
Syswin will work for all CXXK Omron PLC's (as will LSS, but it is VERY old)
Comm settings have been provided for you by jrwb4gbm. Settings on back of host link must match settings in Syswin. Ensure "unit number"(Syswin communication setup, under Project Tab, communications) match host link "Machine NO.".
The host link has the comm data, not the PLC. That is what the Host link is for. You have the correct Host Link.
Don't mess with your PC comm data, just ensure you have the correct serial port selected in Syswin, usually Com1.
MRPLC.com is a great resource.
http://forums.mrplc.com/index.php?showforum=17
I matched the machine number, parity, baud rate and CTS to 0V and I still recieve an error "No response from the PLC". Any ideas??
I need assistance connecting to a C60 K PLC using a Host Link 3G2C7-LK201-EV1 Thanks!
2,703
I am looking to make some minor changes in a old system that we have, and I am not very well versed with the OMRON line of products. This is the...
4,851
have a question that I have not been able to find a answer to by reading the omron manual. Have some older equipment that have a omron c60h plc...
5,313
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
46
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
185
