Omron CJ2 Hard Coded String TXD/RXD
netdomain
May 2013
toronto
Hello all,
I am trying to send some strings to a serial card to communicate to a hand held scanner.
I know I can save strings in registers and send it to the device but I wonder if there is a way to hard code a text in an omron instruction?
For example,
TXD "abcd" D5
Instead of storing "abcd" into D4
TXD D4 D5
is it possible with any omron instructions or I am stuck with precoding each register with a string and use that to send?
You will need to precode the registers with your data.
The "S" Source node will not allow a constant value to be entered.
Not what you wanted to hear, but hope this will help.
I'm working on a welding machine run by an Omron CJ2M-CPU35 When the operator tries to run one of our sequences, the PLC goes into an error state...
4,373
I am using direct operation and have my EtherCat setup to handle 9 servos (Basic Positioning). Does anyone have a reference with multiple servos...
1,498
Hi, Sorry if this has been already posted elsewhere, I couldn't find it doing a quick search. Can anyone advise whether there is a totaliser...
4,318
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
148
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
87
