Omron CJ2M - making RPM from a binary input
lesalte
Mar 2011
Norway
Hi!
Need some help on a schoolproject!
We have an optical sensor, that counts 12 pulses per rotation on the shaft on a machine.
I would like to convert this information to RPM, it is some kind of function in the PLC i can use, or must I make it myself?
I have tried making a FB but I cant get it to work, it is attached.
Thanks for any help!
If you want that PRM value is updated every minute:
Use a timer 1_minute to generate one-shot pulse everuy minute (CLK pulse)
Use a DM0000 and increment it continuosly od each postitive change of IN pulse from sensor.
When CLK pulse is on, then:
-Divide DM0000 with 12
-Stroe reult in DM0002 (that is RMP)
-clear DM0000
Each minute you will get a new DPM data in DM0002.
If you want that PRM value is updated continously:
Measure time interval between two IN pulses (from sensor), using internal 0,02sec pulse. (50 pulses counted = 1 sec =1/(60*12) rpm
Reset measurement on falling edge of IN pulse.
If you want to use intergated HSC (high speed counter) inputs (if exists on CPU):
Use instructions foh HSC.
CJ2 does NOT have High Speed Counters on base PLC! You would need to add either a CJ1W-CT021 HSC module OR a CJ2M-MD21 Pulse I/O module to use HSC functions.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
185
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
74
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
114
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
123
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
245
