Omron CJ2M Memory Card replacement
lpons
Oct 2013
Toronto
Hi All,
as in the title I'd like to check with you some thoughts I have regarding the Omron Memory Card option offered with the CJ2M series PLC (and of course, I think also the other series).
I've done some research and the FLASH memory card looks like a good old CompactFlash memory card which is sized in three different formats: 128MB, 256MB and 512MB. Omron offers the three of them as guaranteed working and, of course, it pretends also a copious amount of money for this nice feature.
What I was wondering is: is there someone who can confirm that, if I use, for example, a SanDisk 128 FAT-16 formatted (http://www.bestbuy.com/site/sandisk...1305499520.p?id=mp1305499520&skuId=1305499520), this one will work properly as the one provided by Omron?
Thank you to everybody
Cheers
LP
That' why I was asking. I've seen the thread about that memory card used on a NS touchscreen but I wanted to be sure. Thank you anyway! We'll see if someone else has tried it.
Contact your Omron office - they will tell you. I think it does but not 100% sure.
Omron's CJ2M has a compact flash card slot. Can an Omron program simply be copied to a compact flash card using a Card Reader or must it be loaded...
3,035
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
166
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
106
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
115
