Omron CJ2M Memory Card Trasfer
fnewman3
Aug 2014
Pennsylvania
Omron's CJ2M has a compact flash card slot. Can an Omron program simply be copied to a compact flash card using a Card Reader or must it be loaded on the card using the Omron CX Programmer software?
I mistakenly identified this as a CPM2A earlier as I am currently working with both.
You will need to use CX-Programmer to transfer the files to the memory card.
If the program is in the processor, you can use the Simple Backup process to save processor memory to the card.
Information is in the W473 manual.
Hi All, as in the title I'd like to check with you some thoughts I have regarding the Omron Memory Card option offered with the CJ2M series PLC...
4,580
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
145
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
102
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
112
