Omron Comms
kb9tua
Mar 2008
Anderson. SC
We have an Omron PLC w/CJ1M CPU11 PA202 processor.
We have new comms cables. We have CX-Programmer v4.02 software. We used to be able to make changes to the PLC program. The last change that I attempted to make, we received a comms error. Nothing that I've tried has enabled us to communicate with this PLC. I've been able to communicate with other PLC's of this nature. I believe the com port on the PLC might be damaged. It has a display that connects to the peripheral port, that isn't having any issues. I have a new processor on order but, I don't know when it will get here. Is there any way to set up PLC comms through the peripheral port instead?
Check CPU dipswitch #5 for ON position. If ON, you should be able to connect Sysmac WAY 7,e,2@9k6.
If off, it follows the port settings as set in the PLC setup.
Hey y’all, I have been tasked with establishing comms between an Omron NJ and a Toyopuc PC10G via Ethernet IP. Does anyone here have any...
1,273
Hi. First post here. Hoping to get some help with a m221 im using with machine expert basic to communicate with an omron HMI. Im using Ioscanner...
37
6,533
Hi, I'm looking into a way I can share data between an old Omron CQM1H-CPU51 PLC and an S7 1200. I've done a similar thing with an old Siemens...
5,671
Hello, I was hoping for some help in trying to read/write to a handful of bits in a CJ1M-CPU13 controller from a Compact GuardLogix. The CJ1M...
1,820
Hi All, Can anyone tell me if its possible to program an Omron CS1G-CPU43H via an inserted CS1W-SCB41-V1 2 port communication module, on port 2...
2,425
