Omron CP1H Motion
chunkheng
Sep 2007
Malaysia
Hi All,
I am using Omron CP1H, trying to move a motor, I am using the built in pulse output to generate pulse, the pulse output method is "pulse+direction" (NOT CW/CCW).
For now, I can always move the motor in ONLY 1 direction. Any hints that can help me to move the motor in a reverse direction?
Thanks.
thanks for your reply, Sergie.
Yes, you were right, The setting in the driver caused the problem.
Thanks.
However, I am having few other questions after I got the motor moving in both directions.
1. I see a lot of "PV"'s in the programming manual. What does "PV" stand for?
2. I am used to developing PC-based programming for the motion, in which I can keep track of my position using the built-in API.
For CP1H, is there any way I can keep track of my current position (means how many pulses I have sent out, etc.)
Thanks.
The PV (Present Value) is the motion axis actual coordinate.
However, it must be preset by INI instruction. Until that no absolute moves are possible and on relative moves the PV resets on each move start.
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,719
I have a question about SET instruction in Cx-programmer. When condition goes true it is supposed to give value 1. But, my controller is giving 0...
24
2,304
Hello Sir/Ma'am, Hope you and your family are safe in this Covin-19 Pandemic. One of my client have a machine in their ceramic industry which...
2,625
Hi, I recently had to buy a batch of new electrical components containing 10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used...
3,570
Hi, i'm using cx programmer 9.5 running on my vmware and trying to connect to my CP1H- XA. I did the required driver installation suggested in the...
2,869
