Omron-CP1W-DA041
osmanjdt
Jun 2016
johor
108
There have 2 different value in configuration output 2 on Omron CP1W-DA041 manual which one the correct?
thanks for your time.
Thanks for your feedback,
fully follow the instruction but still not working,still working on it.
maybe missing something.
Are you using the First Cycle Flag A200.11 to initiate the MOV instruction?
Is the Destination channel of the MOV instruction correct?
Is the Source of the MOV instruction have a # prefix?
Just a few of the things I have seen.
Hello, I have a CP1H-XA4001 PLC, with a CP1W-DAB21V option board. The moment I insert the board, the PLC goes into Error. I set the dip switch to...
1,502
Hi all, This is my first post on here, hopefully you can all help. I'm very new to PLC's and have been given a project at work that's currently...
3,729
Ok I have an CP1W-C1F41 Ethernet Comm module added to my CP1L PLC. What I am trying to do is set it up (IP address etc). I can not find a manual...
2,617
Brand new to Omron My supplier speced CP1H-XA490DT1-D CPU with 2 CP1W-20EDT1 expansion modules Using CX One Lite I can't select the CP1W units...
3,195
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
