Omron CP1W-DAB21V
aandjsam
Sep 2016
lincolnshire
30
Hi all,
This is my first post on here, hopefully you can all help.
I'm very new to PLC's and have been given a project at work that's currently above my skill level. The task I've been given is as follows:
I've got a production line with 14 sensors on, these will go to a PLC (Omron CP1L-EL) which is connected to a HMI and an analog output module to go to a LCD display to show the product count. The issue is when I connect the analog output expansion module (CP1W-DAB21V), as soon as I connect this to the PLC the 'error' indicator illuminates.
Can anyone shed any light on this, I'm lost with it...I've read in some forums that I may have to put an always on flag to a DM bit, is this the case?
I'm afraid I'm going to hassle you guys a lot over the next few weeks as this is all alien to me!
Thanks in advance,
Sam
That worked a treat, thank you. I've come to the programming now and so far I've found that I'll need to use the 'Scale'/SCL instruction with a source word, which i was planning to take from my cumulative value of all of the counters, via a MOV bit (that might not be the best way to do it?) then the result word as a value to then convert to 0-10v. However, the 'First parameter word' is the one I'm unsure of.
I've come across the Arithmic process APR function before, but do I need that as the output I'm generating will be linear?
Again, any help is massively appreciated.
Thanks,
Sam
If all of the counters that you want to add are sequential (C001,C002, etc) you may be able to use the SUM(184) instruction to add them together. If the are not you will need to use individual +B(404) instructions to add them all together.
Hello, I have a CP1H-XA4001 PLC, with a CP1W-DAB21V option board. The moment I insert the board, the PLC goes into Error. I set the dip switch to...
1,502
There have 2 different value in configuration output 2 on Omron CP1W-DA041 manual which one the correct? thanks for your time.
2,300
Ok I have an CP1W-C1F41 Ethernet Comm module added to my CP1L PLC. What I am trying to do is set it up (IP address etc). I can not find a manual...
2,617
Brand new to Omron My supplier speced CP1H-XA490DT1-D CPU with 2 CP1W-20EDT1 expansion modules Using CX One Lite I can't select the CP1W units...
3,195
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
