Omron Cpm1a
Lc1
Jan 2014
Uk
59
I have recently purchased an old Omron Cpm1a plc to practice on. I have a version of syswin that does not require a licence to program these plcs. My issue is that syswin will not speak with the plc.
The plc came with a programming cable and drivers which I believe are installed correctly but still no communication.
Can anyone help with this issue please?
I am running syswin from a Microsoft tablet, windows 10, it seems to load fine and I can create programs. the usb to serial cable came with the plc. I am going to double check the drivers for the cable as they may not have installed properly.
I've got an upload from an Omron SYSMAC CPM1A PLC but I cannot figure out for the life of me how to document the inputs and outputs. It's version...
3,276
I have a Omron PLC with CPM1A-MAD01 anaolog input output module its reading pt100 temperature probe. When the machine is running it starts to...
1,090
Hi, I have recently being using a Omron CPM1A-40CDR-D-V1 and transferred an old program on it. I was testing the program and making some...
4,244
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
4,000
Dear all PLC's master, I'm trying to connect CPM1A to rotary encoder (Omron E6B2) using PRV with this code (0 0 DM100), but i can't read the...
6,157
