Omron CQM Password
I believe there is a one time key from Omron based on some number (serial). It has been a long time since I put passwords exactly for the same reason. If you feel like playing with Macros do a Google search for password guess software and make sure you don't get any viruses with it. I guess this is for uploading from PLC.
You will find no help on cracking passwords on this site!!!
If you are the legal owner, contact Omron.
If by chance you are using a hand held controller;
1. When plugging a hand held in, the display will say "PASSWORD". This prevents accidental changes or unauthorized staff to pick the hand held up and fool around. This is a different issue than the program being Password protected.
2. To allow the hand held to do anything you must push the following keys: "CLR" than "MONTR" than "CLR". (This information is public knowledge as it is documented in the manuals.)
3. If the program is still password protected, what you will be able to do is limited, ie: monitor the status of bits and registers.
Hope this helps
Hello..all i have 1 project to upgrade C200HE to CQM1 omron plc ..need expert suggestion been told to change old model to CQM! model ..which i...
3,764
I am involved in a project where we need to extract about 50 or so bytes of data from 2 Omron CQM1 PLC's (for a production monitoring system). We...
2,324
hi, i am not familiar with omron cpus and i have to add some new commands. i modified the program but i couldn't download because it gave an um...
6,216
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
68
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
