Omron CQM communications
DazEddie
Nov 2003
I am involved in a project where we need to extract about 50 or so bytes of data from 2 Omron CQM1 PLC's (for a production monitoring system). We have been informed by the customer that in both cases, the serial port is in use.
Can anyone suggest an alternative method of data extraction bearing in mind that the rs232 port is in use.
FYI: PLC1 - CQM1 CPU21, PLC2 - CQM1 CPU41-V1
The CQM1 has 2 com ports
The second is behind a flap marked 'peripheral'
It is a mini connecter you will need a CQM1 CIF01 module to convert to standard 9 pin d connection.
Not to confuse the issue, but this may be a good time to consider a hardware upgrade. The CQM1/CQM1H hardware has been discontinued (End of March 2012). CQM1 was discontinued in 2001.
If upgrading is not an option, your only real option would be serial using the CQM1-CIF01. Controller link was only available on certain CQM1H cpu's.
Hope this will help.
Hello..all i have 1 project to upgrade C200HE to CQM1 omron plc ..need expert suggestion been told to change old model to CQM! model ..which i...
3,746
i have omron plc cqm and i forget password can i unlock it anyway?
2,549
hi, i am not familiar with omron cpus and i have to add some new commands. i modified the program but i couldn't download because it gave an um...
6,207
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
132
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
