Omron CQM1H-CPU51
Samsuri Moin
Nov 2017
singapore
Hi there, currently my company is using Omron CQM1H-CPU51 for machine production . I did plc program modification using TTIM (totaliziing timer) function. After I successfully transfer the modify prorgram to the cpu, I test run the program but my TTIM is not counting. I did set the dip switch no.4 to On stage but still no progress on the TTIM. Is there any thing that I missed out? Please advise. Thks.
Why? They have not been manufactured for years and are no longer supported. Tell your company to get with it and use modern PLCs. There are some examples in the manual for using TTIM is it supported in these old timers?
Check your set value. Make sure that if you want a specific number to use the # infront of the number. If you do not, the PLC interprets this as a channel (register) that contains the number.
TTIM (BCD): #0000 to #9999
Regards,
Hi, I'm looking into a way I can share data between an old Omron CQM1H-CPU51 PLC and an S7 1200. I've done a similar thing with an old Siemens...
5,649
good day all i have a problem about my omron cqm1h all program was lost. they gave me a memory card module then i load it but there is no...
2,916
Hi user ! Now,I have problem with PID in Omron PLC (PLC CQM1H-CPU51). My PLC have ADO41(ADO41 is analog input,data between addresses...
17
8,287
Hi all I have a Omron CQM1H-CPU51 and it has bad com port so I need to change it out I am not that fimilar with this pcl I do see that there is a...
8,779
Hello there, I'm Edgar. I'll tell you all what's exactly happening: I'm working in a large Tuna Canning Company, where employees work with Omron...
1,912
