Omron cqm1h maths help
Jayden
Dec 2007
camperdown
41
Hi everyone,
I am generally comfortable with AB PLC's and programming but have recently acquaired a job where I need to modify an Omron Cqm1h PLC. I am having trouble with the data conversions required to do maths instructions. I have a flow meter giving a pulse input to a HSC and I need to do a MULL(56) to get the correct value on an NS series screen but cant understand what I need to do to convert from Dint to BCD for the instruction and then convert back again etc. I have attached my current Cx programmer image. As I said I am not very good with Omron programming at all therefore a step by step guide may be needed for me to understand!
The NS screen can be set up to do the maths
what are you needing to do?
Never mind, after a bit more study I found some double binary instructions that did the job for me.
Thanks for the response
Hi Everyone, I have a customer that needs a CQM1H (CPU51) replaced. They purchased the processor new-old-stock from a source they found online...
357
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
886
Hello maybe someone can help me, I have omron CQM1H PLC with CLK21 (Controller link module) and SCB41 (Serial module connected with NMB CSD-891B...
546
Hi, I have an Omron PLC (CQM1H-61CPU) connected to an Omron HMI (NT631C). In order to connect a PC to them, I want to know: 1- Is the cable...
867
Hello, i have a omron plc with cqm1h cpu, and is protected by um read password i need any program to crack it lik xtal, plc backup tool v6 with...
1,074
