Omron CX-Programing SCL not working!
blackbird307
Jun 2015
Winnipeg
59
I am trying to scale my analog input from 1-5V to 0 to 1000. My parameters are
D290
D290 + 1 = 0000
D290 + 2 = 0064 (1V)
D290 + 3 = 1000
D290 + 4 = 01F4 (5V)
All entered through Memory
I can see my input is 0 - 1000 from 0 - 10V however, my final variable D150 returns 0 BCD, no matter what my input is.
What am I doing wrong??
From what I understand the parameters for SCL take up 3 additional addresses including D290. So D290 + 1 + 1 + 1 ie D290 , D291, D292, D293.
In the memory I wrote out as the following
290 : 0000 (BCD, according to manual for instruction)
291 : 0064 (Hex for 1V, according to manual for instructions)
292 : 1000 (BCD again)
293 : 01F4 (Hexadecimal for 5V)
D150 is my output for which I am expecting a BCD value, but it seems all I see is 0.
My analog input, A642, reads 0 - 1000 in decimal. 1000 being 10V, which is the maximum intended value for the analog input.
I have it written out as SCL(194) A642 D290 D150 .
Thanks again!
Use the scaling function in my post above - I hate function blocks but love this one and use it all the time. Also you do not mention which scaling function you are using - there are 3 in the later Omron PLCs and then there is APR for non linear functions. Which PLC? Which analogue card? Give us the important information as well please - some of the older analogue cards could be scaled in the card - was really easy.
I am using a CP1L-EM30DR, it has 2 built in analog ports which seem to work fine. I am using SCL (194). I will try that function block out.
Please suggest me programing cable for omron plc sysmac model no. Cpm2a
1,139
Hi All, Can anyone tell me if its possible to program an Omron CS1G-CPU43H via an inserted CS1W-SCB41-V1 2 port communication module, on port 2...
2,421
Hi, I did a search forthis on the site and found a link to page 1728 but not post about this??? any answers? Thanks, Steve
7,390
I need some help getting the TC102 module working. I want to ON/OFF regulate, and the transmitter is a PT100. When W0.00 (se picture below) is...
3,433
hi all, Is there some one there to help me out for this interesting omron logic?? the thing is that let us assume that i have D0 to D5000 memory...
4,491
