Omron CX Programmer and dates
MortenB
Apr 2016
Fredrikstad
I'm all new to using omron but "stuck" with a project. I find the CX Programmer software (version 9.35) a bit confusing. Used Siemens a lot.
What I'm trying to do is to display date and time on a HMI showing cpu startup time. I use a "First cycle flag" that triggers once when CPU starts and then I understand that the date and timestamp is in the system variables A352 and A353. But how do I format them as a normal text? I only manage to display them as #hex-numbers.
I have tried googeling but have not found an answer to my questions.
CPU type is: CJ1M CPU12
//Morten
:cry:
"How do I format them as a normal text?"
If you want them in the ASCII format then use the ASCII Convert Instruction ASC(086). It will convert 4 digit Hex to 8 bit equivalent ASCII.
Regards,
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
397
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
756
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
2,008
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,082
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,313
