Omron CX-Programmer - Read bit status of DINT
I select the PLC memory addresses so can place in any area such as CIO, W, etc that I need to.
What I don't understand, is that if you are responsible for the memory allocations etc, why not just create the symbols per bit etc?
Sometimes, you have to adjust your style to suit the tool you are using 🤾
The Customer specified that all OPC communications have to be DINT so they are requiring my symbol name to be DINT. I don't want a symbol that address the DINT and another symbol that addresses the individual bits that I have to maintain. The unions under Syswin would have been perfect but I don't see them under CX.
The problem with this, is that this series of Omron are 16bit memory locations, so there has to be some sort of memory management by someone.
This has caught people out before that are not aware of how 16/32 bit data types work etc.
Is not only Omron that had this sort of issue, all processors that did not have dataType specific memory locations are susceptible.
SYSWIN had unions? I know Sysmac Studio does.
See if the attached helps.
The bitz.zip is the "Cat's Meow"! It works great. The only issue is the bits are backwards from what I normally think of as bit 0 but I can easily work around that.
Thanks a bunch!
If you know the bit number you can address it directly with that CPU.
N/O D15000.02 out 260.00. Many processors do not allow bit addressing in DMs or registers - that processor does.
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
388
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
750
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,994
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,072
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,304
